How to compare the OPD different of different configuration?
  • Oct 13, 2023 9:07 PM UTC
  • 131 views
Yujie
Hi Experts,
I want to check the OPD different of different configurations. But I found that I can only check the OPD within one configuration only. I just need the OPD different of the chief rays of different configuration.
Any ideas of it will be appreciated.
Thanks!
Best answer by Kevin Scales
Hi Yujie,
If you’re using a tool like OPD Fan, you can find a selector at the top of the window that allows you to choose the configurations. The options are generally Current, 1 / 2, 2 / 2, etc, and sometimes all if it is relevant to look at all configurations at the same time. The Current option selects whatever configuration is used in the Lens Data Editor.
Is this what you had in mind?
Kevin Scales
  • Nov 1, 2023 10:18 PM UTC
Hi Yujie,
