How to calculate PSF correctly in a paraxial equivalent Zernike design?
  • Jun 11, 2025 9:04 PM UTC
  • 78 views
A_Ke
Hi there,
I found a very helpful description of Mark Nicholson on “How to model a black-box optical system using Zernike coefficients”.
When I start calculating Huygens PSF in that paraxial equivalent model, I see some deviations to the real system (especially when I go to large field angles).
Why and what should I consider to make Huygens PSF work “correctly” in that case? Any ideas?
Kind regards!
