How export sequential lenses with rays to CAD file
  • Mar 10, 2025 9:38 PM UTC
  • 6 replies
  • 510 views
jsung
Not sure if this topic was discussed before, but I haven’t found it yet.
Sometimes I need to export lenses to CAD file (STEP or X_T) including ray bundles for each object field. What is proper setting for having rays that can be viewed in program like Solidworks?
For example I tried the setting below, but this STEP file didn’t display field cone rays in SW.
Regards
JS
​@jsung
There used to be a knowledge base article about it, but I can’t find it anymore. I would have thought it would be in this article, but it only has Autodesk and Creo:
https://support.zemax.com/hc/en-us/articles/11623397624467-How-to-show-exported-rays-in-the-CAD-platform
However, this was previously discussed in this community, such as in the following posts:
There’s also a Youtube video from Opto-Mechademic that shows how to do it:
https://www.youtube.com/watch?v=WLrNWfvVgOE
  • Mar 12, 2025 1:49 AM UTC
​@David.Nguyen
You are correct.
I remember clearly there is a section on how to export rays to Solidworks in this KB article.
Remove this section may due to competitor relation between Ansys ,Dassault  even with Simens.
Yang.Yongtao
  • Apr 24, 2025 4:29 AM UTC
Hi Jsung
 if you use solidworks, try this
YANG
Yang.Yongtao
  • Apr 24, 2025 4:30 AM UTC
Hi Jsung
YANG
Yang.Yongtao
  • Apr 24, 2025 5:01 AM UTC
for your reference
or this may work… I accidently meet the AP242 issue
jsung
  • Apr 29, 2025 9:23 PM UTC
Yang,
Thanks for your screenshots of SW general settings. I have settings just like those shown above.
What I found is that unchecking the “parasolid library” did trick to show exported rays as mentioned in other KB thread David posted above.
However, if I try to export the ray footprint to 3D file I need to have that “parasolid library” checked. So it seems I can either export rays or footprint to 3D, but not both together.
JS
