How can I draw the edges of an air spacer?
I’d like to display the edges of an air spacer like this:
How can this be done in Zemax?
Best answer by Mike.Jones
Create fictional glasses that have a refractive index of 1, done by setting a0 in the Schott dispersion equation to 1.0 and the rest of the terms to zero.  Set the wavelength range to 1E-9 and 1E+9. Set the density and TCE to whatever the spacer metal is. Name it "aluminum", "titanium", "SS-304", etc.  Create a "METALS" library for your new glasses.
Using these fictional metal glasses in the LDE will enable Zemax to draw the spacers, and model mass and thermal dimensions properly.
Mike.Jones
  • July 1, 2024
Thanks for the tip Mike!
