Hot spots in fly's eye beam homogenizer
  • December 1, 2021
  • 570 views
Hi.
I found hot spots in the Detector of the fly's eye beam homogenizer.
I don't understand why it occurred and where did it come from.
Is it a real physical situation?
Thanks.
Best answer by Jeff.Wilde
Your optical path is not constructed properly.  Here’s the setup for a homogenizer based on a single lens array.
A simple rearrangement of your optical path looks like this:
Note the plano-convex lens has been flipped to reduce aberration.  The hot spots are now gone.
  • 491 replies
  • December 1, 2021
