Haze and Hal power angle
  • October 11, 2022
  • 138 views
Luca.cellerino
Good morning to all,
in order to integrate data from plastics manufacturers, I came across the "Haze" and "Half Power Angle" values of the attached datasheet (see in second page at section “optical properties”). How can I integrate these values into the characterization of my personal material catalog?
Thanks a lot.
Hi Luca
I think “Haze” and “half power angle” will be modelled as scattering, so basically applying a scattering model to your surface / object: https://support.zemax.com/hc/en-us/articles/1500005575662-What-scattering-models-are-available-in-OpticStudio-
I looked quickly at the wikipedia page since I am not familiar with these quantities https://en.wikipedia.org/wiki/Haze_(optics) but from my understanding the % of Haze is the Fraction to Scatter and the angle gives the distribution.
Luca.cellerino
Hi to all,
I'm trying to make OS calculate (through a merit function) the possible mean paths and angles. I don't know how to tell the system to take the detected peak value and divide and halve it.
Thanks a lot
Hi Luca
