Global Coordinates in Sequential Mode
  • May 4, 2022 7:08 PM UTC
  • 676 views
dmansur
Is there a way to assign a different global coordinate system to a configuration in sequential mode? This picture explains my predicament. I have four configurations which are spaced evenly in the X-axis by changing the offset in the 3D settings. What I’d really like is to display a 2 x 2 array. Is there any way to do this without converting to non-sequential mode?
Best answer by dmansur
OK, I think I solved it. I set thickness on surface 0 to be 1e-5, then added a coordinate break on surface 1 and made Surface 2 my global coordinate reference, and now I can move things about as I wanted.
Your suggestion definitely led me down the right path. Thanks for the help!
It looks that you should add a coordinate break and shift object accordingly for each configuration.
dmansur
  • May 5, 2022 1:41 PM UTC
Thanks. My problem is that I can’t seem to add a coordinate break before the object.
dmansur
  • May 5, 2022 1:59 PM UTC
