Glass selection for VIS/SWIR (0.40µm to 1.70µm)
  • Oct 12, 2021 10:09 PM UTC
  • 156 views
zjwalker
Hello lens designers, what common glass types do you use to balance chromatic aberration over the visible to SWIR bandpass, say 400nm - 1700nm?
It is quite large spectral range.
I suppose the glasses will depends on the requirements of your system and design type. For me it is enough hard to give you a set of glasses.
