Getting text file from object detecotr
  • February 10, 2025
  • 246 views
Hi all,
I am using a series of cylindrical pipes as detectors to simulate my system. I want to export the text data from the detector viewer for each of the cylindrical pipe detectors.  I added an example file and my script below. Whenever I try to export the data, it will not change the .CFG to the correct detector. I tried setting the detector to the correct object and saving the .CFG but it still would default to a different detector. Any idea how I can export the txt for each object?
! Program Variables
detector_number = 4
source_number = 1
!Create config by saving in Detector Analysis window.
settingsfilename$ = "H:\TEST_FILE.CFG"
! Create a filepath for .txt file
filepath$ = "H:\DATA.txt"
! Clear Detector
clearing = NSDD(1,0,1,1)
! Trace Rays
NSTR 1, source_number, 0,0,0,1,0
! Change detector CFG ot Correct Detector Object
MODIFYSETTINGS settingsfilename$, DVW_DETECTOR , detector_number
! Opens Detector Viewer
OPENANALYSISWINDOW "Dvr", settingsfilename$
! Export Open Detector data to .txt
GETTEXTFILE filepath$, "Dvr", settingsfilename$
@Chris.Ladas
Somehow I cannot download your file.
Anyway, I think if you add the flag value 1, it’ll work:
GETTEXTFILE filepath$, "Dvr", settingsfilename$, 1
From the Help Fille:
Let us know if it works for you.
  • February 13, 2025
@Chris.Ladas
  • February 13, 2025
Thank you David!
That fixed my issue.
