get image simulation result
  • Mar 2, 2022 6:18 AM UTC
  • 732 views
Using Extended Scene Analysis > image simulation,
settings:
pixel size=0.02
X pixels=3000
Y pixels=1000
After Save as, we can get the picture as below,
but this image simulation result is limited by screen size.
Could I get a 3000x1000 pixels image(bmp)?
Thank you~
Best answer by Chenfeng.Gu
hi Anna
you want to save the simulation result? Like the following?
Maybe the following Macro can also do favor for you?:candy:
Copying Image Simulation images in ZPL macros
Chenfeng.Gu
  • Visible
  • Mar 2, 2022 10:49 AM UTC
Hi Anna
I think maybe there is some mismatch between the Field Height Setting and the Detector Settings
Just for your reference, here is an article about image simulation: How to simulate high resolution images
There are also some interesting posts on the forum, maybe you can find the answer:
  • Mar 2, 2022 12:14 PM UTC
Hi Anna
Hi Chenfeng,
Sorry I didn't explain my problem well.
Thanks for the reminder,  there is some mismatch between the Field Height Setting and the Detector Settings.
I want to get the photo size equal to the CMOS resolution.
But the saved photos are like image screenshots.
How do I get 3000 x 1000 pixels photos?
Thank you~ :relaxed:
Chenfeng.Gu
  • Visible
  • Mar 2, 2022 12:32 PM UTC
hi Anna
  • Mar 7, 2022 2:26 AM UTC
hi Anna
Hi Chenfeng,
Thank you :)
