Gaussian beam size at various location of the model eye
  • April 15, 2024
  • 13 replies
  • 357 views
Thaniga
Hi All,
I am currently working on simulating the Gaussian spot size at various locations within the eye model, such as the cornea, lens, and retina. I have attempted this using both paraxial Gaussian beam analysis and Physical Optics Propagation (POP); however, the calculated values do not align with my theoretical expectations. According to theory, I expect the spot size to be approximately 44 microns at the lens, around 90 microns at the cornea, and roughly 280 microns at the retina. My source has 840nm wavelength. I attached my Zemax file for your reference . Could you please assist me in accurately simulating the Gaussian beam in Zemax to achieve the desired values?
Thank you in advance.
Thanigachalam P
Lenror Li
  • Visible
  • April 26, 2024
Hi Thanigachalam,
   Can you share the information about the laser source used for the theoretical calculations?
Thaniga
  • April 26, 2024
Hi Lenror Li,
A 840nm, 15mW diode laser emits a collimated output beam with a diameter of 3mm.
Thanigachalam P
Lenror Li
  • Visible
  • April 26, 2024
Hi Thanigachalam,
    What is your theoretical calculation method for obtaining the result? Does the laser source have other parameters such as divergence and beam quality?
Thaniga
  • April 26, 2024
Hi Lenror Li,
I assumed the beam to be perfectly collimated, implying negligible divergence, and hence assigned an m² value of 1.
Thanigachalam P
Lenror Li
  • Visible
  • April 26, 2024
Hi Thanigachalam,
How do you obtain the data and verify its accuracy?
“According to theory, I expect the spot size to be approximately 44 microns at the lens, around 90 microns at the cornea, and roughly 280 microns at the retina.”
Thaniga
  • April 26, 2024
Hi Lenror Li,
Apologies for any confusion. The beam from the objective lens converges at a distance of 34mm. Will this information suffice, or do you require additional data? The attached Zemax file contains the complete design.
Thanigachalam P
Lenror Li
  • Visible
  • April 28, 2024
 Hi Thanigachalam,
       I cannot find the data you obtained theoretically in the file, so I wonder how you obtained the data.
Thaniga
  • April 29, 2024
Hi Lenror Li,
For basic calculations, regardless of the system, I treated the entire setup as a single lens with a back focal length of 34mm. Considering an input of a collimated beam with a diameter of 0.8mm, an M² value of 1, and a wavelength of 840nm, I calculated the waist size at the focal point to be approximately 45 microns, utilizing the formula:
2𝑤0=4𝑀2𝜆𝑓/𝜋𝐷​
Without factoring in human eye refractive index and aberrations, I estimated the waist size at a distance from the focal point to the cornea (~3.6mm) to be around 100 microns and from the focal point to the retina (~18mm) to be about 300 microns, using the formula:
𝑤(𝑧)=𝑤0⋅ sqrt[1+(𝑍/𝑍𝑟)^2]
Despite these basic estimations not approximately also aligning with my zemax POP data.
​Thanigachalam P
Lenror Li
  • Visible
  • April 29, 2024
Hi ​Thanigachalam,
      Yes, basic calculations can acquire data through formulas, and I believe there is no error.
And when you input the correct source parameter into the POP data, you can obtain the same result.
Thaniga
  • April 29, 2024
Hi lenror Li,
Thank you for your feedback. According to the theory, the waist size should be 45 microns. However, I noticed that the input provided indicates a waist size of 1.46mm. Could you kindly provide clarification on the reasoning behind this deviation?
Thanigachalam P
Lenror Li
  • Visible
  • April 30, 2024
Hi ​Thanigachalam,
     I misunderstood your previous idea; I believe the POP data is correct because when I simulate with the perfect laser system, I obtain the same result. The differences in the data you obtained may be due to the aberrations of the lens system.
Lenror Li
  • Visible
  • April 30, 2024
Hi ​Thanigachalam,
This article may help you.
Paraxial gaussian beam data | Zemax Community
Thaniga
  • April 30, 2024
Hi Lenror Li,
Thank you for your information.
Thanigachalam P
