Finding the original STOP position in a patented design
  • Sep 15, 2020 3:59 PM UTC
  • 6 replies
  • 596 views
Dear OpticStudio users,
I had to replicate the design of a patented lens (US patent US7199938) in the context of my research at the MRC - Laboratory of Molecular Biology. In this patent, all surfaces are thoroughly described (radius, thickness, refractive index, and Abbe number), but it is never specified were the STOP position is. It is the second time I am facing this issue, and here is how I went about it:
  1. I have reversed the objective lens to have the specimen plane as the IMAGE plane. I am doing so because, usually, the aperture is at the back of the objective lens, and I can avoid using ray aiming (in the end I don't think it makes a big difference, and its probably fine to work with the forward model).
  2. I have created 5 equal area Y fields (only along Y because it is a rotationally symmetric design) that fill the field number of the objective lens.
  3. After the OBJECT surface (Surface 1), which has an infinite thickness in the reversed state, I have put a dummy surface (Surface 2) with a variable thickness.
  4. After the dummy surface, I have put the STOP surface (Surface 3), and its thickness is a pick-up of the dummy surface (Surface 2) with a -1 scale factor.
  5. I have created a default Merit Function to optimize for the spot size,and ran the automatic local optimizer.
This virtually placed the STOP surface where it gave sensible results (based on a comparison with a matrix optics approach). I didn't have to place thickness constraints on the variable thickness, but it can be done if necessary, I guess.
What do you think about this method? Can you see any downfalls? What other reverse engineering tricks do you use to get this kind of information?
I happy to make a more pedagogic post if there is an interest in this topic.
Kind regards,
Angel Morales
Hi David!
Nice to see a familiar face :) hope you're doing well!
As far as I know, I have seen this method of 'floating the STOP' used to find the potential best starting point for this surface at initial stages in the design, though applying this technique to locating 'best' position for a patent certainly makes sense to me. I suppose since patents like these are meant to be demonstrative, the priority in your case seems to be placing the STOP so that you receive the same performance as the literature describes.
Of course, the only 'downfall' I could see in this case is that the STOP surface gets too close to a lens edge (if you're trying to make it a separate aperture from a lens), that the STOP becomes embedded inside a lens element, things of that nature. At this stage, though, you're trying to ballpark it anyway, so you could then use the optimized result to decide whether the STOP should be a separate aperture or an actual lens surface.
I don't have much to add in terms of other 'reverse engineering' tricks, but I'd be curious to hear from other members of our community! It would certainly be interesting to see what other ideas folks have had :)
~ Angel
  • Sep 17, 2020 3:53 PM UTC
Hi Angel,
I am well thank you. I hope the same for you too :)
That is absolutely correct. if I could reproduce the results demonstrated in the patent, then I would be confident about the STOP position.
This is what happened. After optimisation, the STOP was right in the middle of an actual lens, which I'm not sure is physical actually.
Yes, I'm hoping to get good input from this discussion with other engineers.
Take good care of yourself Angel,
Hi David,
Your method sounds like it is really finding the pupil, not the stop. Pupils are usually virtual, so having them appear to be in the middele of a lens is not unusual.
Try creating the file as a non-sequential file, and fire rays that overfill the first lens into the lens from a couple of field points as well as on-axis. Look at where the ray bundles overlap or have their closest approach. Doing this from the front and back of the lens is probably a good idea.
Also, sometimes a lens aperture of mount is the stop, so don't be surprised to find a stop on or near an optical surface.
HTH,
- Mark
  • Sep 18, 2020 9:09 AM UTC
Hi Mark,
Thanks for your answers.
It does make sense. Depending on the lens orientation, I am probably more likely to find the entrance, or exit pupil. I completely overlooked this issue.
Do you think there still is a chance for this method to actually find the correct STOP position considering the pupils are images of the STOP?
I'll definitely try the non-sequential method.
It does help a lot Mark, thank you, and take care,
Angel Morales
Hi all,
Mark, that's a great point you brought up I totally overlooked also. I suppose if your pupil aberrations aren't too bad, you could still 'eyeball' the approximate STOP position based on where your dummy pupil surface lands. I used the Cooke Triplet as a quick test -- I did a quick local optimization for spot size in the original file first, then I added a 'floating' dummy surface, made it the STOP, and did another optimization just varying that thickness, which made the following trace:
Showing just the physical surfaces:
It looks like a good candidate for the STOP position is at the second lens (which is where it is placed in the sample file), since this is where all the field points are overlapping. Of course, it's not perfect, as it will be obfuscated by any pupil aberrations for your system. But I suppose it at least gives you an idea, which you can then physically define and optimize a bit further to see if any higher performance can be achieved.
I've also attached the file here for reference!
~ Angel
  • Sep 21, 2020 9:29 AM UTC
Hi Angel,
Great work, and it makes sense.
On my end, I had a go at the non-sequential approach proposed by Mark (see figure below).
One can see where the fields overlap, and it also probably a good STOP candidate (note how the fields overlap on a curved surface, could it be pupil aberrations?).
On the other hand, in the sequential file. The optimised STOP surface, and the surface where the fields meet seem to nearly coincide (see figure below).
While I still haven't wrapped my head around both methods. It gives me a good idea where to look for the real STOP position.
Thanks a lot for your help, and take care,
