Find vignetting surface
  • February 18, 2022
  • 533 views
John.Hygelund
If you system has vignetting, is there a way to list surface(s) are doing the vignetting?
Thank you,
John
Best answer by John.Hygelund
Hi Jeff, thanks for pointing out this ZPL function.
Not very elegant, but this does the trick! Much more efficient than manually stepping through the surfaces
! Find vignetted surface
FOR I, 0,1,.1
RAYTRACE 0,1,0,I
V = RAYV()
FORMAT 1.1
PRINT "Hy=1.0, Py=",I," first surface to vignette: ",V
NEXT
Example output
Hy=1.0, Py=0.0 first surface to vignette: 0.0
Hy=1.0, Py=0.1 first surface to vignette: 0.0
Hy=1.0, Py=0.2 first surface to vignette: 0.0
Hy=1.0, Py=0.3 first surface to vignette: 11.0
Hy=1.0, Py=0.4 first surface to vignette: 11.0
Hy=1.0, Py=0.5 first surface to vignette: 11.0
Hy=1.0, Py=0.6 first surface to vignette: 11.0
Hy=1.0, Py=0.7 first surface to vignette: 8.0
Hy=1.0, Py=0.8 first surface to vignette: 8.0
Hy=1.0, Py=0.9 first surface to vignette: 8.0
Hy=1.0, Py=1.0 first surface to vignette: 8.0
  • February 19, 2022
Hi John,
One option could be to write a short ZPL script to trace a set of rays that originates from one or more field points and spans the pupil, then use the RAYV function to get the surface number(s) at which vignetting occurs
and print those surface numbers (and of course once a given surface is found to be vignetting for any one ray, it doesn’t need to be printed again).  Something similar could also be done using ZOS-API.
John.Hygelund
  • February 22, 2022
FOR I, 0,1,.1
RAYTRACE 0,1,0,I
V = RAYV()
FORMAT 1.1
NEXT
Example output
saif
  • September 18, 2025
I would like to reopen the topic ​@Jeff.Wilde ​@John.Hygelund .
I am designing a fiber to chip coupling system using micro-lenses and i would like to know exactly from which surface beam is clipping/vignetting? I have attached my design. I have limited understanding on the ZPL function that ​@John.Hygelund shared.
I used polarization in POP and it showed me reduced coupling efficiency and as i understand that using polarization considers vignetting rays..
Please suggest. Thanks
Regards
saif
John.Hygelund
  • September 30, 2025
@saif , The macro here is intended for standard sequential ray analysis and I don’t think it will help if you are using POP.
