Field Lines through 1 arcsecond slit - won't fit
  • February 9, 2024
  • 122 views
whit2452
Hello there, I am still a new learner to Zemax.
I have an optical system of 7 lenses focusing collected light from a telescope onto an image plane. My goal is to image 1 arcsecond portion of the sky and add a 1 arcsecond slit. Given the F#, diameter, and EFFL of the telescope, I calculated a slit width of 0.0097 mm.
I am running into a problem inserting a slit of this width inside the system. The field lines that pass through it have to be so small,  (0.0001, 0) (-0.0001, 0) (0,0). Is this normal to block out that much light?
Here is a screenshot of my series of lenses. Aperture slit location is sized up and highlighted in orange.
h4op31LGgX95QMKVpk9FbjkRAtlDcvkjmvHT2d1jbqZ__KfGIGWMtdzCsr4ftowW6jd1LBZlrM2bdxZprpDJOvdiLcOScv7jg_9N6DvlArzSCZXZQA8_t5RAkvpy0W1_lJBAeb-nTxJmVXLFG8XV14G3GQ=s2048
Here is a zoom in of the slit, only allowing (0.0001, 0) (-0.0001, 0) (0,0) field lines through.
Tg5ytDjwubjR6cotVxUkdNt4CyQZZljx-DAyJWVOZYKhWpqfLI5Le-xI49udi10SZb5H9ScxlQtA_x2Zk9RBZnB2WWcFua1LhaFlIl66gIObp7uR97AsCoyFkSIgootIyRNnNo02Z_fIzmvAM9PJtWIE6g=s2048
Best answer by Naif.Alsalem
Hi Whit2452,
If I understand you correctly, I think you are talking about the slit height rather than the slit width. You can calculate the slit height (mm) using this formula:
Once you find the required slit height (length), you can set the dimensions of the focal plane (img) to be your slit.
Best
Naif
Hi Whit2452,
Best
Naif
