FFT PSF shows nothing, is blank and Zemax goes down
  • Mar 16, 2023 11:37 AM UTC
  • 389 views
Marzanna
Here is my very simple setup
and its spot diagram, which is smaller that Airy Radius, so I wanted to investigate PSF further using FFT PSF
but I don’t get any image, just black window
After that, Zemax is slowing down, stopped work and closed. When open Zemax again,  I am getting this message
I have tried with other file ( but with similar simulations) it is happening again - I am getting black screen for FFT PSF and Zemax is down. I am sure my laptop has enough RAMs to accommodate Zemax.
Marzanna
Hi @Marzanna Please contact our support.
Hi @Marzanna !
Do you still have the issues? Have you tried the troubleshooting steps here: https://support.zemax.com/hc/en-us/articles/1500005578222-What-to-do-if-the-graphics-windows-in-OpticsViewer-are-black-or-blank
Marzanna
  • Mar 28, 2023 8:06 AM UTC
Hi Sandrine,
Although I gained access to certain Zemax functions that caused the software to crash, the issue was not solved, and I will have to work around it.
Marzanna
