Feature Request: ZOS-API Layouts Exports Completion
  • November 29, 2024
  • 194 views
One year ago, ​@Xianglei wrote a topic (thanks a lot!) about:
Since its been quite painful to generate such plots with ZPL (thanks to ​@Erin.Elliott, we might get a fix in 2025 🤞):
I’ve been using the ZOS-API option more and more to create animations. It is more stable, but currently lacks a couple of options. Since we’re approaching the Christmas period 🎅, this is my wish list to improve the ZOS-API Layout Exports feature (in order of importance):
  1. As far as I understand, we cannot specify the file type of the export. I’ve tried to use multiple extensions in OutputFileName (.JPG, .PNG, ...etc.) but the file size remains the same. Based on the file size, which is rather small (for a given image size), I’m assuming the export is made in .JPG regardless of the extension specified. Can the file type be added to the ZOS-API?
  2. Could we get a vector graphics file type?
  3. Although there’s a property RaysLineThickness, for me, it doesn’t seem to have an effect. If someone is anyway going to look at this, would it be possible to have a line width (integer) property instead?
  4. Could you also add a property to disable the RGB axis at the bottom-left corner of the layout?
Thanks a lot,
  • December 2, 2024
Hi, David.  1 and 3 sound like possible bugs.  Could you work with Support, so they can check those and submit, if needed?
  • December 2, 2024
Thanks ​@Erin.Elliott. Does the ZEMAX support address still work? Because I have an academic license and last time I checked I couldn’t login support tickets.
Angel Morales
  • December 5, 2024
Hi ​@David.Nguyen, thanks for the post here and the questions. We’re looking into the points 1 and 3 mentioned by Erin. Looking at 3., it does indeed have an effect for me, same as the Layout plots in the GUI. We are taking a closer look at 1 as well.
To speak to the question of support, in general, academic license questions indeed need to go through our forums (see the section Academic Support in the link). For OpticStudio questions, at the moment we are monitoring questions here on community.zemax.com, but questions can also be asked at our Ansys Learning Forums.
That said, if bug-related issues arise and there is a need to hand-off confidential data to investigate the bug, we can open a discussion separately (that is, not public) to preserve proprietary/sensitive information.
Regarding your issue with the rays thickness not changing, how are you accessing the ZOS-API -- Python, MATLAB, etc.? I checked with Python and it seemed to work fine, so checking in your language would be the next thing I should do.
Thanks, and looking forward to hearing back!
  • December 5, 2024
Hi ​@Angel Morales, good to hear from you.
Regarding 3. I’m actually using ZOSPy, and I don’t want to add to the confusion by sharing my code here (unless necessary). I tested again today, and you are right that RaysLineThickness works. Its just that the difference between thickest and thinnest isn’t obvious (zoomed-in screenshots below).
Ray Line Thickness = Thickest
Ray Line Thickness = Thinnest
I’m using pixel width/height of 3840/2160. There is no bug in that sense, but if we could have a bit more control over the thickness of the rays that would be awesome 😃
