Exporting Ray Data sets, Specific formats
  • May 9, 2023 7:03 PM UTC
  • 1159 views
James
Dear ALL:
      We’ve been asked to look into exporting ray data from a Non-sequential Zemax model in the following format style.    The first few (6)  terms look to be part of the ZRD command.
        The format is::   x, y, z, L, M, N, Lumens, Wavelength."
But how would one also get the Lumens and Wavelength data ?  Wouldn’t that only be available  at a DETECTOR plane ?
Thank you in advance.
[Mod note: moved to more appropriate forum for OS-related discussions.]
Best answer by yuan.chen
Hi James,
You may check the last message in this post: How to save detector ray data as a source file | Zemax Community
If the data is saved as .sdf format, it could contain the wavelength and energy information.
Speos and Zemax Source file converter – Knowledgebase
If you want to reformat the .sdf data, you can use the python code here:
Python Reading Writing Binary Files (ZRD, ZBF, DAT, SDF) | Zemax Community
yuan.chen
  • May 10, 2023 6:58 AM UTC
Hi James,
