EULUMDAT .LDT FILE and FILE METADATA WHEN IT IS EXPORTED
  • Jul 31, 2023 6:07 PM UTC
  • 81 views
Dear all,
Does anyone knows how can i configure or set up the file metadata or header when .LDT file is exported?
I have a NSQ design that uses a LED source (OSRAM 4000K one). When i try to export the .LDT from the polar detector i noticed that the metadata inside the .LDT file shows that CCT is 3000k instead of 4000K.
how can i configure that?  I thought that .LDT did not include that parameter.
thank you for your help in advance
SP
