Error code 300002 during step file import
  • Nov 24, 2026 10:52 AM UTC
  • 23 views
jesusmunozjmj
Hi guys!
I am are trying to solve an issue I was not having when I was using Zemax 2017 version. I have my optical system in Non-Sequential mode with a STEP file that is in the correct folder for this purpose. Everything works well with the old version of Zemax I have from 2017, but once I try to open this with the new version I have from 2025, I see this error on the NSC 3D Layout:
“Import of file C:\Users\xxx\Documents\Zemax\OBJECTS\CAD Files\xxxx.step for object 44 failed.
Modeling operation failed with error 3000002: Maximum model dimension exceeded.”
I have double-checked and it is the same optical design and the same step file. The error is gone if I change the scale from 1 to 0.3, and I see the cad file on the layout with the optical system, but if the scale value is higher than that, the problem comes back. And, of course, I would need the scale to be 1 as it was exported from the software. Do you guys know what’s happening?
jesusmunozjmj
It’s not a real solution but I got the component imported correctly in STL.
It can be a way to avoid this problem if the accuracy of the export is not critical.
Jesús
