EFLY/EFLX operands considering Zernike coefficients
  • May 5, 2025 11:17 AM UTC
  • 257 views
so far I was under the impression that the EFLY/EFLX operands ignore all Zernike coefficients (e.g. of Biconic Zernike surface) and purely consider the radii of curvature . Now I discovered that the coefficient “Zernike 4” and its effect on the curvature is considered for EFL calculation. Although the Zernike 4 polynomial is proportional to r² and thus directly changes the effective radius of curvature, it is by far the not the only Zernike polynomial effecting the EFL in X- and Y-direction (e.g. Zernikes 5, 6, 11, 12, 13, ...).
Is this change in EFL calculation a bug or intented?
What was the OpticStudio release this change in ELFY/EFLX was introduced with? I could not find any mentions in the release notes.
Simon
Best answer by Jeff.Wilde
Hi Simon,
It looks like sometime in 2019 a change was made regarding how EFL values were calculated.  As far as I can tell, it happened between OpticStudio 18.9 and OpticStudio 19.4, both of which were released in 2019.  Originally, EFL was based on paraxial ray tracing, then it converted to parabasal ray tracing.  Not completely sure if that coincides with EFLX/EFLY calculations incorporating any surface parameters that affect the nominal base radius of curvature, but that would be my best guess.
  • May 6, 2025 5:46 PM UTC
Hi Simon,
