Edge Cut for Mounting
  • June 4, 2021
  • 42 views
Hello everyone,
First of all, I wonder which tag I should use for Lens Data related thread which takes place in setup ribbon in ZOS.
Second, which is my main question, I want to give a reshape to my lens as seen below;
How can I give this type of cut at the edge for mounting purpose?
Thanks in advance, Any help is appreciated
Csilla Timar-Fulep
Hi Önder,
Thanks for your question here on the forums!
You can change from different types of edge connections under the Draw tab of the Surface Properties:
You may find a detailed description of the different possibilities together with example drawings in the Help sysetam at:
The Setup Tab > Editors Group (Setup Tab) > Lens Data Editor > Surface Properties > Draw (surface properties)
I hope this helps, but if you have any further questions, please let us know and we will be happy to help!
Csilla
  • June 9, 2021
Thank you for your help Csilla. I tried to give the exact view to my lens using the draw menu, but I couldn't give the desired shape edge to my lens yet.
