Diffuser with Gaussian scattering model
  • Nov 10, 2023 2:52 PM UTC
  • 813 views
I have implemented a simple system composed of:
  1. Diode Source with 2deg divergence in x and y;
  2. Diffuser implemnted with cylinder volume with a single scaterring surface following a gaussian model with sigma = 0.27
  3. Polar detector to monitor the angular distribution of energy after the diffuser in the range -90, +90 deg;
After exporting the detector data using the ”Detector Viewer", I have fitted the data points with the gaussian model described in the Help documentation: BSDF = A*exp(-x**2 / sigma ** 2):
The value of the fitted sigma (sigma_i = 23.194) has nothing to do with the specified sigma of the diffuser (sigma = 0.27), which tells me that my interpretation of the scattering model is wrong. Where does the discrepancy come from?
  • Nov 13, 2023 12:05 PM UTC
Hi Jonasz,
Unfortunately, the documentation for the Gaussian scattering model is deficient (to say the least), and none of the online articles I have seen help. Hopefully someone from Zemax see this thread and update the documentation (if my explanation below is correct, that could be just a matter of adding 1 or 2 sentences).
Most diffusers communicate their scattering angle in degree (sometimes FWHM, sometimes 1/e, ...), however Zemax’ Gaussian scattering model is not a Gaussian distribution in angle (unlike LightTools for example). The scattering formula is applied in cosine directors space (that is closer to the physics). As a result, the scattered cone becomes elliptic when the incidence is not normal. However, the value at normal incidence is the one you want to use for the definition.
So the sigma in Zemax is most likely following the sine of the angle, which for 0.27° would be 0.0047 (sigma is dimensionless according to the documentation, so that looks consistent. There may be some factor 2 or sqrt(2) to account for.
Of course, that is contradictory with the documented value of 5 for Lambertian (a sine of 5 is not really defined for an angle). A long time ago, I ended up computing tabulating values from 0 to 5 and their resulting sigma in ° in Excel and interpolating the value. The sine formula matched this tabulated way within 1% up to 10°, 5% to 25°, 10% to 40°.
  • Visible
  • Nov 15, 2023 11:51 AM UTC
Dear Ray,
Indeed, the manual entries on scatering models is lacking.
I´ve tried to fit the formula using the cosine directors but still did not manage to find an agreement between the nomimal sigma and the fitted sigma. In the end I followed the black box approach, similar to the your tabulated data approach.
Kind regards,
  • Nov 15, 2023 11:55 AM UTC
Hi Jonasz,
Did you get a value close to 0.0047 to work for your 0.27° ?
jesusmunozjmj
Hi ​@Jonasz and ​@Ray
I just ran into the same issue. Has anyone found the relationship between the sigma value and the angular distribution? I modeled different sigma values across a range of angles with a Detector Polar and found an almost linear relationship up to sigma = 1, where the linear behavior breaks down.
Figure 1. Gaussian sigma = 0,0015.
Figure 2. Gaussian sigma = 0,015.
Figure 3. Gaussian sigma = 0,15.
Figure 4. Gaussian sigma = 1.
Has anyone figured out how this sigma value actually works?
Jesús
