Diffraction grating line frequency
  • Feb 13, 2025 9:02 AM UTC
  • 183 views
AsafPe
I ordered a Blazed (Ruled) Grating and datasheet specify 1200 Grooves/mm
What is the Lines/um I should use in for the Diffraction grating surface to simulate that?
Thanks
​@AsafPe
If one groove is one line (reasonable?), then 1 200 / 1 000 = 1.2 lines/um?
AsafPe
  • Feb 13, 2025 1:19 PM UTC
Thank you  David, that’s what I thought but it doesn’t fit with the diffraction orders angle. It looks like there is a factor of 0.5 missing (0.6 lines/um) like one groove which is also the grooves pitch, is half a “line” ???
​@AsafPe
I would ask your manufacturer to clarify what a groove is.
OpticStudio uses this definition:
Which seem to agree with this Wikipedia figure from the Diffraction Grating article:
The refractive indices in the Wikipedia formula were omitted:
The sign difference is due to the different case treated: reflection in Wikipedia and (probably) transmission in OpticStudio Help File.
I hope this helps.
