Difficulties while balancing CRA, Distortion and MTF
  • Jun 16, 2026 11:23 AM UTC
  • 14 replies
  • 287 views
Thaniga
Hi All,
I am currently designing a low‑cost imaging lens for a sports application. In my lens model I use the REAY operand to control image height, the RAID operand to control chief‑ray angle (CRA), DIMX to control f‑theta distortion, LACL for lateral‑color correction, RSCH for spot size and MTFT/MTFS for resolution across the field. During optimization I can obtain either good MTF or good lateral color with CRA and distortion depending on the operand weightings, but I cannot find a stable balance even when I adjust the weights gradually. In both cases, my geometric spot‑size results were poor. Please suggest optimization techniques to achieve a better trade‑off, or alternative approaches to indirectly control these parameters.
Note: candidate glass materials must have hardness greater than 450.
Thank you in advance for your support.
  • Jun 16, 2026 11:32 AM UTC
Hi Thaniga,
Can you please share your zemax file?
It will be easier to help that way.
Nadav
Thaniga
  • Jun 16, 2026 1:17 PM UTC
Hi Nadav,
Thank you for your immediate response. Apologies, I do not have permission to share the zemax file in the forum. Hope you understand. Please guide me to get the result by direct/ indirect optimization technique. Also, suggest me how to pick the low cost high hardness material in granta material picker.
Thank you for your support.
  • Jun 16, 2026 1:19 PM UTC
Ok. understood. Can you share image of the system and the ray tracing? without knowlege of the system it will be hard to help
Thaniga
  • Jun 16, 2026 1:39 PM UTC
  • Jun 17, 2026 4:29 AM UTC
Hi Thaniga,
We will need to know more about the systmem: Field of view, stop size, effl, total length etc. Also the required prefromance. Without, it will be very hard to help. Did you try wavefront or contrast optimization?
And regarding the hardness, you can make a catalog with Hoya glasses(hoya hardness glass table-first result google), use GCOS operand to control the price and then use hammer optimization with glass substitution.
B.R
Nadav
B.R
Nadav
Thaniga
  • Jun 18, 2026 6:47 AM UTC
Hi Nadav,
Thank you for your continued support. Basic requirements: DFOV 110°; F-number 2.2–2.4; TTL < 38 mm; wavelength range 430–650 nm; maximum image circle 10.2 mm; front lens diameter < 22 mm (including mechanical housing); lateral color < 4 µm; chief ray angle (CRA) < 12°. I evaluated the design using contrast optimization with weighted improve manufacturing yield.
Thank you once again for your support.
  • Jun 18, 2026 7:11 AM UTC
Thanks for the input. We also need any other constraint like: Detector size, stop size(looks like 6-8 mm right?), maximum weight, no of lens etc. can you please share your mtf graph?
Nadav
Dear Thaniga,
It's very difficult to advise remotely without access to the file. But here are a few remarks and suggestions I can offer:
- In your specifications, you don't mention axial chromatic aberration, only lateral! Why?
- LACL is a paraxial operand, which is therefore of little use since, in your case, the field of view and aperture are large.
- You say "lateral chromatic aberration < 4 µm," but what will your pixel size be?
- I don't understand why you're using RSCH. If you optimize with the "spot" method, you reduce transverse aberrations and therefore the size of the image spot.
- Optimizing on the MTF is a bad idea. It significantly increases the optimization load, making it less efficient.
- What I would do:
* Have few operands in the MFE. Rather than hoping Zmax will do the work on its own (it won't), try to assist the optimizer. We are incredibly fortunate to have a brain, and we must use it!
* Assess the geometric and chromatic aberrations and tackle the most significant ones. In general, Zemax corrects geometric aberrations quite well. However, chromatic aberrations are more difficult to correct. A Hammer optimization could help, except that in your case, you have 8 lenses. You will be faster by manually changing the materials and relying on theory.
Could you show us the "chromatic focal shift" curve and the "ray aberrations" curves at the maximum field of view?
I hope this will be useful to you
Thierry Lépine.
Thaniga
  • Jun 19, 2026 10:34 AM UTC
Hi Nadav,
Thank you for your feedback. Here is the MTF plot. Detector size: 1/1.6 inch and current stop size is 4.5 for f/2.4 and 5mm for f/2.2. As I share the layout, the current system consists of 6 singlets, 1 doublet and 1 Filter.
BR,
Thanigachalam P
Thaniga
  • Jun 19, 2026 10:46 AM UTC
Hi Thierry,
Thank you for your intense feedback. For our imaging application the small change in later color will affect chroma. Though we consider the longitudinal CA, but lateral color plays major role. I used LACL with target of 2microns for min to max wavelength change. But it doesn’t give good performance.
My pixel size is 2microns.
I tried with “Spot” optimization function with MTFT and MTFS operands to control MTF. But performance was not up to the mark.
Please review the Chromatic focal shift and ray aberration curve.
BR,
Thanigachalam P
Hi Thaniga,
Not surprising as I told you.
Same !
Please could you magnify the central part of the ray aberration curves  @ max field & tangential plane (ey) ?
Thank you.
Thaniga
  • Jun 19, 2026 2:12 PM UTC
Hi Thierry,
Here is the magnified version of the ray aberration curve at max field.
Tried different options like changing the materials, design approach and all. The bottle necks are front lens diameter, Knoop hardness >450HK, TTL and wavelength range.
Actually, I got good results for 486nm to 656nm wavelength. But the requirement is from 436nm to 656nm.
I’m looking for an out of the box suggestion to use the tool more effectively.
Thank you very much for your support.
OK
  • the lenses are too thick (rule of thumb : thickness ~ diameter /10). This could help for TTL.
  • are there aspheric surfaces ?
  • did you try to separate L6 and L7 ?
  • did you try to move the stop ?
  • for sports applications, do you really need 436 nm ?
  • from CFS and ray aberrations : try to increase the Abbe number of L8
  • ultimately : change the starting point. See for instance “Modern lens design”, W. Smith
Thaniga
  • Jun 22, 2026 8:01 AM UTC
Hi Thierry,
Thank you for your response,
  • The above layout lenses are thin lenses basically, first lens has 1.5mm thickness, expect the thickness of first lens of doublet lens, all other has less than 3mm thickness.
  • Since this is very low-cost approach, there is no aspheric surfaces.
  • Tried separating the lenses and varying the stop location using MCE individually to compare the performance.
  • Yes, the 436nm is mandatory requirement. Then only they can see clear separation between violet and blue.
  • Ok, will try to do it.
Thank you for your support and suggestion.
