Detector Color Setting in NSC
  • Nov 15, 2023 6:58 AM UTC
  • 404 views
Yadong.Wang
Hello @Mark.Nicholsonand ZEMAX engineers,
I am comparing the color detector results of my file to your NSC projector tutorial in Youtube:
Projectors Part 6: System Performance - YouTube
I found that for the same filament settings (with 5m rays and normalized lumen 1) as yours, and detector dimension+pixel. My simulated results (top three figures) are very noise compared to your simulation results (bottom three figures).
I saw in your video that you only used the normal Ray Trace. I am puzzled now how to improve the results or there is a mistake in my setting…(I have tried to increase the simulated ray numbers, it helps a bit to smooth the plot, but never as smooth as your level with only 5m rays)
I have included the NSC files for your reference. Thank you in advance!
Best answer by Yadong.Wang
Hello @Mark.Nicholson,
I think I have figured out the which setting made such a difference.
In my original color/spectrum settings. I selected wavelength from 0.38 to 0.78 and the number of spectra is 3. When I increase the spectrum to 7 or higher, I can see my simulated results of color detector became smooth with 5m rays and sampling method set as Sobol. 😅 Thank you for directing my attention to the source page, that I started to pay attention to the spectrum settings. Have a nice day.
Please change this question to solved. Thanks.
I’m away from my PC right now so I can’t check, but see if Sobol Sampling of the source is on. Otherwise I’ll look at it Friday when I’m back
Yadong.Wang
  • Visible
  • Nov 16, 2023 12:48 AM UTC
Hello @Mark.Nicholson ,
Thanks for the reply. Yes, the Sobol Sampling is by default turned on.
The number of rays on your detectors are ~960k, and my numbers are in the 700k range. But I do not see this will make a drastic difference in the plot uniformity.
Please kindly check this if you are available. Thank you and have a nice day!
Yadong.Wang
  • Visible
  • Nov 16, 2023 2:59 AM UTC
Glad I could help - Mark
