Cutting multiple polygons
  • Jun 26, 2022 10:58 AM UTC
  • 201 views
Hi all,
I want to cut muliple polygons like that:
  1. Making the polygons.
  2. Rotate them.
  3. Cutting them all to fill a surface of another polygon.
Is there any way to do step three in a simple macro?
thanks,
Nadav
Hi Nadav,
I’m not entirely sure what you meant with your question, but here’s a macro (also attached to my answer) that should do something similar:
# Number of polygons
n_poly = 5
# Spacing
spacing = 1.5
# Angle
angle = - 5.0
# Insert a Rectangular Volume for overlay
# Insert new object
INSERTOBJECT 1, 1
# Change new object to Rectangular Volume
SETNSCPROPERTY 1, 1, 0, 0, "NSC_RBLK"
# Change overlaid volume size and position
# (should be computed instead of hard-coded)
# Y1 Half Width
SETNSCPARAMETER 1, 1, 2, 0.8
# Y2 Half Width
SETNSCPARAMETER 1, 1, 5, 0.8
# Z Length
SETNSCPARAMETER 1, 1, 3, (n_poly + 1) * spacing
# Z Position
SETNSCPOSITION 1, 1, 3, - spacing / 2
# Change opacity
SETNSCPROPERTY 1, 1, 142, 0, 5
# Loop over the polygons
FOR idx, 1, n_poly, 1
    # Insert new object
    INSERTOBJECT 1, 2
    SETNSCPROPERTY 1, 2, 0, 0, "NSC_RBLK"
    # Change Rectangular Volume position and angle
    SETNSCPOSITION 1, 2, 3, spacing * (idx - 1)
    SETNSCPOSITION 1, 2, 4, angle
    # Hide object
    SETNSCPROPERTY 1, 2, 141, 0, 1
    # Insert new object to undo the rotation first
    INSERTOBJECT 1, 3
    # Reference new object to the polygon
    SETNSCPROPERTY 1, 3, 2, 0, 2
    # Undo the rotation
    SETNSCPOSITION 1, 3, 4, - angle
    # Insert new object to perform intersection with
    # overlaid Rectangular Volume
    INSERTOBJECT 1, 4
    # Change to Boolean Native
    SETNSCPROPERTY 1, 4, 0, 0, "NSC_NATB"
    # Update Ref Object
    SETNSCPROPERTY 1, 4, 2, 0, 3
    # Undo axial translation
    SETNSCPOSITION 1, 4, 3, - spacing * (idx - 1) - spacing / 2
    # Edit object composition
    # Object A = Overlaid Rectangular Volume
    SETNSCPARAMETER 1, 4, 5, 1
    # Object B = current Rectangular Volume
    SETNSCPARAMETER 1, 4, 6, 2
    # Edit boolean operation
    SETNSCPROPERTY 1, 4, 1, 0, "A&B"
NEXT
It creates a large rectangular volume (hard-coded), and 5 default Rectangular Volumes. Then, it adds axial spacing between the default Rectangular Volumes, and rotates them by the same amount. After that, the macro adds Boolean Native objects which perform the interesction operation (&) of each default Rectangular Volume with the large rectangular volume (I colored the polygons manually for illustration purpose, I don’t think this can be done in ZPL 😥):
The trick is that the axial offset and rotation have to be undone to reposition the Boolean Object, since we first applied the axial shift and then the rotation, they should be undone in the opposite order. First, we have to undo the rotation, that is why the script adds a Null object that references the default Rectangular Volume and perform the opposite rotation. Then, the Boolean Native is referenced to the Null object and the axial shift is undone. This can be made a little simpler if you just tilt all 5 default Rectangular Volume, perform the boolean operation and then shift them axially, but since you asked with your steps in mind, this is my solution.
I hope this makes sense.
  • Jun 27, 2022 1:00 PM UTC
Hi Nadav,
n_poly = 5
# Spacing
spacing = 1.5
# Angle
angle = - 5.0
# Insert new object
INSERTOBJECT 1, 1
# Y1 Half Width
# Y2 Half Width
# Z Length
# Z Position
# Change opacity
    # Insert new object
    INSERTOBJECT 1, 2
    # Hide object
    INSERTOBJECT 1, 3
    # Undo the rotation
    INSERTOBJECT 1, 4
    # Update Ref Object
NEXT
  • Jun 28, 2022 8:12 AM UTC
Hi David,
Thansk a lot for the detailed answer.
Will it also work when some of the polygons at the edges are different in structure:
Sorry for the first explantion. My bad.
Thanks and best regards,
Nadav
Hi Nadav,
Yes, it should still work fine. The & operator in the Boolean Native takes the intersection between the two Rectangular Volumes. However, you should be mindful of the relative coordinates between the objects.
Depending what you ultimately want to do, there might be easier way around this problem.
  • Jun 28, 2022 9:09 AM UTC
Ok. Thanks again
