Coordinate breaks causing unexpected behavior with spot diagram (afocal)
  • September 11, 2023
  • 56 views
BStassel
Hi all, I am only 2 months in to learning Optic Studio so maybe this is a lack of my understanding instead of the program behaving weird.
Attached is the .zmx and .zda files in question for reference.
Essentially, I have a number of OAPs that are collecting and down-collimating an initial flat-top laser beam that has been focused to a target. In my process of designing the system, I have been checking the focal spot and wave front using ray optics as each optic is added. When I was double checking a previous leg of the system, I noticed one of the “Dummy” surfaces had drastically changed.
Above is a spot diagram showing surface 10 “Dummy” perfect focusing for ray optics. But, when I change the Tilt About X on surface 16, it changes the spot diagram for surface 10 by shifting it from the center.  Below shows the effect.
0.001 degree tilt on surface 16
 I am at a loss how changing surface 16’s tilt would affect surface 10.
Please help me understand what is going on and how I should fix it.
Be the first to reply!
