Dear All,
Do you know if it is possible to convert a Zemax file into a file readable by the CODE V software?
Thank you in advance for your help.
Aniello
Best answer by Andrey.Pravdivtsev
View originalDear All,
Aniello
View originalIf I correct there was zemaxos_to_cv.seq macro that can directly read zmx file.
Hi Aniello,
It was in CODE V: Tools - Macro Manager - Sample Macros - Utilities
Hi Andrey,
My question was how to convert a Zemax file into a Code V file.
The other way (from Code V file to Zemax file), I know how it works.
Thank you,
Aniello
Run CODE V, start the macro and select zmx file to convert. It should read data and insert it into CODE V.
Sometimes there can be errors.
