convert IMA file to BMP file
  • January 7, 2021
  • 198 views
when I try to use bitmap optimization, I found the target file format is BMP. Now I only have IMA file.
Can I convert IMA to BMP file to do optimization?
thanks
Kevin
Hi Kevin
There are several ways you could do that:
- You can simply display the IMA file in the IMA/BIM File Viewer, save the file as a BMP and then crop ithe BMP.
- You could also use the Image Simulation, select the IMA file and then select Show As Source Bitmap. Then in Output File, you can write a name ending by bmp. The file will be saved under \Zemax\IMAFiles.
- If you have Matlab, there are also functions to do these kinds of conversion.
Let us know if you need further help.
Sandrine
Hi Kevin
Sandrine
  • January 8, 2021
Hi Sandrine,
thank you!
Kevin
