Convert from “Real Image Height” to “Object Angle” and reverse
  • 1 October 2021
  • 165 views
   I have a non-rotationally symmetric system and in my application I want to convert “Real Image Height” to “Object Angle” and reverse. The conversion works fine for axially symmetric systems (like Cooke triplet) but it is not working correctly for a non-rotationally symmetric system. By that I mean, when I convert “Real Image Height” to “Object Angle” and then I do reverse, (from “Object Angle” to “Real Image Height”) I do not get the same “Real Image Height” values. I am wondering if there is any issue with “Convert to” or I should use an intermediate step to get the correct conversion.
Soroush
Userlevel 7
Badge +3
Hmm...hard to say without seeing the file, but I’d try looking at ray aiming settings and seeing if they have changed.
Thanks Mark for your answer. Unfortunately, I won’t be able to share the file. I tried different ray aiming settings and I got the same results. This behavior happens when I have a non-rotationally symmetric system and wide angle lens.
Userlevel 6
Badge +2
Hi Soroush
If you can, email the file at support@zemax.com
We can have a look.
