Confusion About Fletch Arrow Direction and Paraxial Focal Length in Zemax
  • April 2, 2026
  • 26 views
Yang.Yongtao
Hi Zemax users,
I am trying to set up a lens system layout as shown below, but I am confused about the following points:
  1. Why does the direction of the Fletch arrows reverse?
  2. Why does the paraxial focal length of the lens not seem to work as expected?
I have attached my data. I would really appreciate any help.
Could you please point out what I am doing wrong?
Expected Layout and Fletch Arrow direction
Attached Zemax Data
Best Regards
Yang
@Yang.Yongtao
I’m not totally sure, but I think both issues are related to the fact that you initiate the ray trace in a backward direction by having the first non-zero thickness negative in a “non-mirrored” space.
If you add a surface after the OBJECT and make its Material mirror, then the “positive” propagation direction becomes negative, and the arrows point in the right direction.
This is the same reason the Focal Length wasn’t behaving as expected as well.
In general, I think you want positive thicknesses until the first mirror, then switch to negative thicknesses until the next mirror, and then alternate the signs between mirrors.
I hope this helps.
  • April 2, 2026
@Yang.Yongtao
I hope this helps.
Yang.Yongtao
  • April 2, 2026
@Yang.Yongtao
I hope this helps.
Hi David,
Thanks a lot!
That’s exactly what I wanted to do. I initially thought that using a negative thickness would make the fletch arrow point in the intended direction.
Thanks again for your explanation—not just this time!
“ In general, I think you want positive thicknesses until the first mirror, then switch to negative thicknesses until the next mirror, and then alternate the signs between mirrors.”
Yang
