Coating CAD object - non sequential mode
  • Jan 20, 2021 3:59 PM UTC
  • 105 views
I can not assign a coating to a CAD object in the non-sequential mode. Is it possible to do?
thanks
Luca
Hui Chen
  • Jan 20, 2021 7:18 PM UTC
Hi Luca,
Thank you for your post!
Yes, it's possible to assign different coatings to different faces of a CAD object in Non-sequential mode. You need to go to Object Properties\Coat/Scatter tab to assign coatings, as shown below.
Could you please give this a try and see if it works?
Hui
  • Jan 21, 2021 8:52 AM UTC
Hi Hui,
I solved the problem. I was using a .STL and the coating flag was disabled, but using a .STEP instead it is enabled.
Thanks for the advice,
regards
Luca
