Coat/Scatter "Face is" meaning
  • Feb 15, 2025 2:45 PM UTC
  • 202 views
mocquin
In the docs:
The Setup Tab > Editors Group (Setup Tab) > Non-sequential Component Editor > Object Properties (non-sequential component editor) > Coat/Scatter
the “Face is” description is :
Face Is This setting controls whether the face is refractive, reflective, or absorbing. The following options are available:
  • “Object Default” means the face is either refractive, reflective, or absorbing, depending upon the material type defined in the NSC Editor.
  • “Reflective” means the face is always reflective. The transmitted part of the light is ignored. “Reflective” assumes the surface is coated with a thick layer of aluminum, with an index of refraction of 0.7-7.0i (at 0.55um). The layer is assumed to be thick enough that no light propagates past the layer.
  • “Absorbing” means the face is always absorbing.
I tried playing aournd with those parameters by setting it on a rectangular volume front face with a detector behing and a detector at 45° and a source ray at 45° incident angle with a single wavelength at 10µm , and found that :
  • Face is Object default, no coating, no scattering : all power goes through
  • Face is Object default, SPLIT (50/50) coating, no scattering: .5W on each detector
  • Face is Reflective with no coating, no scattering: no hit behind the volume in transmission, a about .94W in reflection (so the aluminium I guess)
  • Face is Reflective with SPLIT coating, no scattering: 0W transmitted, .5W reflected (so no more alumnium!!)
  •  Fase is Absorbing (coating disabled): 0W on each detector
mocquin
  • Feb 16, 2025 4:23 PM UTC
Now I’d like to udnerstand what happens if I set the Face to Object Default with a METAL coating:
  • reflected power is .4399W
  • transmitted power is : .3607W
those values are coherent with the Reflection/Transmission curves, but I am wondering how those values are computed ? Because the METAL coating corresponds to a single layer of ALUM2 with index 0.82-5.99i and relative thickness 0.0075092
Is there a thin film equation that is used, in this case with incident media Air, coating METAL, and substrat also Air ? (since the MATERIAL of the rectangular volume is left empty)
