Co-ordinate Break
Dear Sir/Madam,
I am trying to simulate a system conatnig prism to deflect the light. I made prism in sequatial mode by using coordinate break. But when I am trying to use another element after the prism, ray direction is changing (right to left), but it should be form left to right, why it is happing so, what changes do I need to make?
I am attaching the screenshot of the problem as well as .zar file.
This problem is not persisting when I am also going in negative direction (right to left (By chaning the tilt angle in coordinate break column)), but in that case all the sign convention is changing which is obvious.
Best answer by designerguy13-photonics
Chandan.Maurya wrote:
Dear Sir/Madam,
Hi Chandan,
I just saw the design and found that the very first coordinate break seems redundant and finally get this corrected as below. Hope that might help.
Yang.Yongtao
  • 67 replies
  • July 28, 2022
Dear Sir/Madam,
Hi Chandan,
