Can't insert object from part designer
  • Apr 22, 2021 3:17 PM UTC
  • 575 views
Hello together,
I can not import a object I designed in the Part Designer.
When I want to add it to the non-sequential component editor the option 'Type: CAD Part: Zemax Part Designer' is not visible.
Does anyone have a solution for this?
Thank you very much.
Sincerly,
Christian Bründl
Best answer by Berta.Bernad
Hi Christian,
This object is only available in the Premium Edition of OpticStudio, so if you are using a Professional License, you’ll need to first save the part as a .ZPO file and then export it using the “Export As” function from the “File” dropdown in the Part Designer Tab:
And then import it in the Non-Sequential Component Editor using the “CAD Part: STEP/IGES/SAT” object.
Berta
Berta.Bernad
  • Apr 22, 2021 3:43 PM UTC
Hi Christian,
Berta
Hi Berta,
thank you very much!
Best
Christian
  • May 20, 2022 9:42 PM UTC
Hi @Berta.Bernad - I’m also working in Opticstudio Professional… if I import a CAD object as you’ve described, am I still able to optimize certain parameters of the object, or does in need to be a “part designer object” to use this function?
For example I designed a parabolic concentrator in part designer and I’d like to optimize the outer curvature of the collector. Can I set this as a variable parameter even if I save as a .ZPO, then reimport as a CAD Object: STEP?
Thanks
  • May 20, 2022 9:51 PM UTC
Never mind - I found an article that says you can not optimize a CAD part without Premium edition….
