Can grid sag surfaces be used on object surfaces(surface 0)?
  • November 12, 2024
  • 57 views
Jiawei LIU
I tried to change the object surface type to grid sag surface and imported the grid surface data, but the surface sag map did not change. When I imported the grid sag data to any other surface, it was displayed normally, so I am a little doubtful whether grid sag surfaces can be used on object surface(surface 0)? If not, is there any other way? I want to analyze the imaging results of a complex target surface after passing through a certain optical system. Can adding a grid phase surface after the object surface achieve my goal? if yes, How to convert the grid sag surface into the required grid phase surface?
  • 1140 replies
  • November 21, 2024
@Jiawei LIU
I don’t really understand what you tried to do, perhaps you could clarify exactly what you tried in OpticStudio.
Are you aware of this peculiarity of grid sag files:
If you apply the grid sag to a sequential surface, the extension should be .DAT, but if you apply it to an object, it should  be .GRD, the content of the file can remain the same.
