CAD files not visible
  • July 5, 2023
  • 252 views
Hako Botma
OS version 2022 R2.02
My problem: I cannot select/use the new CAD files i placed in Documents\Zemax\Objects\CAD Files.
So when in NSQ mode i make an empty object into a CAD  part: STEP/IGES/SAT object, the selection pop-up does not show the new CAD files, but it shows old CAD files (that i made and used in previous Zemax versions) that are not even present in this directory anymore. And when i select one of these old CAD objects, they are even shown in the NSC 3D layout plot!! How is that even possible? Is it possible to refresh the CAD list?
Best answer by Benjamin.N
Is it possible that your current Zemax version does not actually use the folder “Documents\Zemax\Objects\CAD Files” for CAD files?
You can check the Project Preferences / Folders menu to see in which folder Zemax looks for CAD files.
Benjamin.N
  • Visible
  • July 5, 2023
Hako Botma
  • July 5, 2023
I found that after a laptop replacement i had two, different ‘document’ directories. And Zemax used the other one than where i placed my CAD files. Problem solved! :)
