CAD export
  • Feb 6, 2022 10:52 AM UTC
  • 379 views
Hi all,
I am trying to export the lens in the attached file to cad file(step).
I got an error for surface no. 4 -failed to export.
When increasing the clear diameter of the surface to be the same as the mechanical diameter, there is no problem.
Nadav
Best answer by Sven.Stöttinger
Hi Nadav,
I was able to export your lens from your file without problems by exporting surfaces 2-5. Your error-code did not occur while I was exporting your lens. My OpticStudio Version used to do this is 22.1.
When opened with a CAD viewer the lens looks fine on first glance. In a second try I also increased the mechanical Semi-Diameter of Surface 4 to 43 mm without increasing the Clear Semi-Diameter and it worked, too.
Sven
Sven.Stöttinger
Hi Nadav,
Sven
  • Feb 7, 2022 2:37 PM UTC
Hi Sven,
It is working now after I updated the software to the last vs.
Nadav
