[Bug?] Tilt/Decenter Elements PIVOT not working as expected
  • Oct 12, 2026 11:46 PM UTC
  • 93 views
I applied the Tilt/Decenter Elements to Pivot and Decenter the middle Lens in Zemax example found in "Zemax\Samples\Short course\Optical System Design Using OpticStudio\SC_Tol_Cooke.zmx".
The Pivot X, Y, Z values controls the X, Y, and Z coordinates in lens units of the point of rotation. This point is either in local or global coordinates as controlled by the Global Coordinates checkbox. In this example, it is in local coordinates.
However, the Pivot point as highlighted by the ORIGIN point in Orange works well for X and Y, but not in Z. No matter what value I apply to “THICKNESS” value in surface 3 “Pivot Point” it does not seem to offset the Pivot Point in Z axis.
The GCRS is set to Surface 1
Can someone please confirm if this is the right way to use/apply Pivot and Decenter using the Tilt/Decenter Elements Tool.
Cheers!
Best answer by Sean Turner
This is working as intended. Thickness of a coordinate break defines the position of the following surface in the new coordinate system, and is applied last, regardless of the order flag.
Your surface 3 should not be used to tilt and decenter the lens element. The green coordinate breaks were added because you used a non-zero point of rotation in the Tilt/Decenter Elements tool. Don’t adjust the green rows to tilt your lens, use row 4.
Sean Turner
  • Oct 13, 2026 12:43 PM UTC
  • Oct 16, 2026 7:19 PM UTC
​@Sean Turner  You are absolutely right! Surface 3 is to set the Pivot Point, Surface 4 is to do the actual pivot.
Thanks a lot for clarifying.
Cheers!
