Bug in “Seperate Fields/Configs”?
  • Jan 15, 2024 11:11 PM UTC
  • 179 views
PhotonHerder
I’m using 2023 R2.00
I’m tolerancing a system and when I select “Separate Fields/Configs” the results in the Sensitivity table clearly aren’t right.  The result for the average of all fields (field 0 in the table) shows a large degradation, but for each of the individual fields the degradation is exactly 0.
It’s a single config system with 3 fields.  I’m tolerancing average diffraction MTF.
Is this a known issue?
PhotonHerder
I tried version 19.4 and it works ok.  Looks like it got broken sometime after that.
