Blocking rays
  • Nov 28, 2021 8:36 AM UTC
  • 293 views
Hi all,
Is there any way to block specific rays from propagating in non sequnetial mode?
for example, in the attached file, I want to block only the first source and allow the second one to propgate.
Nadav
Best answer by Jeff.Wilde
Simply set “# Analysis Rays” to zero for the source that you don’t want to use, which effectively blocks it.
  • Nov 28, 2021 5:17 PM UTC
smax
  • Student
  • Mar 16, 2023 5:41 AM UTC
You can use “Annular Stop” to block the rays.
