Beam splitter array
  • March 17, 2021
  • 97 views
Hi All
I had problem when simulating array of beamsplitters(50% and 5% transmission):
The output power is 97% on both cases. It's seem like the coating wasn't defined correctly.
Attached here the two files with the beam splitter polygon file.
Nadav
Hi Nadav
I have replied you in the other post. If that is ok for you, I would prefer to delete this one to avoid duplications.
Sandrine
  • March 19, 2021
Hi Sandrine,
Thanks!
of course.
Nadav
