Average transmission for a wavelength using POLDEFINE/POLTRACE
  • Oct 3, 2022 4:26 PM UTC
  • 245 views
James.Fry
From the OpticStudio manual under Defining Initial Polarization: “No matter which method is selected, the transmission results for unpolarized light will be unaffected because any two orthogonal rays may be traced to compute transmission.”
Does this mean that I can use POLDEFINE 1, 0, 0, 0 followed by a POLTRACE and then POLDEFINE 0, 1, 0, 0 followed by another POLTRACE and average those results to get an average transmission at a given wavelength?
Best answer by Mark.Nicholson
Yes. Unpolarized light transmission can be modeled by tracing any two, orthogonally polarized rays and averaging the result.
James.Fry
  • Oct 3, 2022 5:02 PM UTC
Thanks, Mark.  Just needed some reassurance on that.  I appreciate your rapid response, sir.  -Alex
  • Oct 3, 2022 5:04 PM UTC
Hi John,
Yes, OpticStudio always needs to trace 2 rays when performing a polarization ray trace for unpolarized rays (you need a polarization ray trace to account for things like Fresnel reflections and bulk absorption, even if you want to analyze unpolarized light).
I like to use the CODA Merit Function Operand to investigate polarization ray trace and to compare to ZPL results for verification:
And the ZPL code is:
FORMAT 0.6
POLTRACE 0, 0, 0, 1, PWAV(), 1, NSUR()
POLTRACE 0, 0, 0, 1, PWAV(), 2, NSUR()
PRINT "Jx intensity : ", VEC1(1)
PRINT "Jy intensity : ", VEC2(1)
PRINT "Average : ", (VEC1(1) + VEC2(1)) / 2
