Assign a source to a wavelength (wave#)
  • Jun 26, 2024 12:44 AM UTC
  • 409 views
NielMcC
I want to assign a source to one of the wavelengths in the System explorer (wave#) to show how it can progress through my non sequential system of filters, fluorescent targets, etc.  I tried setting the source properties using the color/spectrum to an actual spectrum file I wrote in the sources folder (even with a monochromatic response at one of the wavelengths) but it didn’t map the rays to the wave# or match the fluorescence wave shift routine.  Is this possible and what are the settings on the source object properties to make this work?
@NielMcC
Sources have a column Wavenumber where you can specify which wavelength from the System Explorer should be traced.
If you use a source spectrum (from the source properties). Then, the rays are traced according to the spectrum you specify.
I hope this helps.
  • Jun 26, 2024 6:52 AM UTC
@NielMcC
I hope this helps.
NielMcC
  • Jun 27, 2024 2:49 PM UTC
Thanks David,
That was very helpful.
Niel
