ASCII Ray file
  • Sep 5, 2019 12:21 PM UTC
  • 260 views
I'm using the binary file converter on your website to convert a .DAT ray file into an ASCII text file:
https://customers.zemax.com/os/resources/learn/knowledgebase/how-to-convert-a-binary-source-file-into-ascii
I should then be able to use this ASCII ray file in my design (I know that raytracing will be much slower). However, I don't know how to import such file in Zemax. It is located in the Source Files folder (same as .DAT ray file) on my computer but it doesn't appear in the list of Data files when I'm using a Source File Object.
What I'm I doing wrong here?
Sebastien
Does your translated file have the .DAT extension?
Also, don't forget to update the list if you add a file to the directory after starting OS:
