Aperture Divergence
  • September 12, 2022
  • 197 views
Hi everyone,
is it possible to model a divergence aperture?
For example i want to set a entrance pupil diameter divergence of 1,6 mRad.
Thanks a lot in advance
Best answer by Ethan
Hi @marco.ievoli,
Sorry about the delayed response. One method to achieve a diverging aperture is by setting the Object Space NA. I’ve put together a simple example below where I set the NA based on 1.6 mRad (assuming the small angle approximation). Then using the equation for NA (from Numerical aperture - Wikipedia) for a given fixed aperture, you can calculate the necessary object distance to make sure that you fill the aperture with rays diverging at 1.6 mRad.
Ethan
Ethan
  • 107 replies
  • December 21, 2022
Hi @marco.ievoli,
Ethan
