all MC configuration captured on one detector in NSC
  • June 27, 2023
  • 156 views
Marzanna
I am changing the light source angle, and then capturing it on the detector in NSC. Is it possible to capture altogether configurations on one detector plane?
Marzanna
Best answer by David
Hi Marzanna,
There are two trace buttons: “Trace” and “Clear and trace.”
Clear and trace clears detectors first, trace does not.
Use clear and trace for the first configuration, then change to the next configuration and use trace. That will add the hits to the detector. If you continue for each configuration you will accumulate the hits as you go.
  • June 27, 2023
Hi Marzanna,
Marzanna
  • June 29, 2023
Thank you David,
BW,
Marzanna
