Aeroglaze Z306 .bsdf data
  • Aug 8, 2024 7:17 AM UTC
  • 321 views
e206894
I need the BSDF data for Aeroglaze Z306 black paint for stray light analysis. I couldn't find it in the ZEMAX database or online platforms. Can anyone help?
  • Aug 8, 2024 12:48 PM UTC
If you need the BSDF, you may need to get it measured.
There are however a few curves in the literature (from a quick google search) with the reflectance as function of incidence angle and wavelength
Fig. 19 of:
https://wp.optics.arizona.edu/optomech/wp-content/uploads/sites/53/2016/10/persky-1999.pdf
Fig. 4 from:
https://www.researchgate.net/publication/252807685_The_Geosynchronous_Imaging_Fourier_Transform_Spectrometer_GIFTS_on-board_blackbody_calibration_system
Other information (reflectance and various angles)
https://digitalcommons.calpoly.edu/cgi/viewcontent.cgi?article=1183&context=star
e206894
  • Aug 9, 2024 6:48 AM UTC
Thank you for your detailed answer, but I don’t have the equipment to measure this data.
The Zemax format for .bsdf data is a bit different—it needs to be directly obtained from a measurement machine. Since I can’t generate sufficient data with graphs alone, I wanted to ask if there is anyone who has already measured this data in a format suitable for Zemax.
