3D Layout gets stuck [Ansys Zemax 2023 R2.02]
  • Feb 14, 2024 11:47 AM UTC
  • 231 views
Has anyone experienced this? The 3D layout gets stuck and unusable. Forcing user to open up new 3D layout window.
Best answer by Sean Turner
This happens pretty often and is very annoying. I have found 2 workarounds that let you keep any window settings.
Clone the window, then close the first.
Switch to classic tab, then switch back.
Mike.Jones
  • Feb 14, 2024 6:20 PM UTC
YES! Many times.  There is a bug in Layout 3D that makes it freeze.  The only possible thing to do is kill it and do another one.  But because that's the workaround, we'll probably never see that bug fixed.
Sean Turner
  • Feb 14, 2024 6:34 PM UTC
