Stock Lens Matching tool - Lens flip side
Show first post
Yihua Hsiao
  • 66 replies
  • October 14, 2021
@David.Nguyen Thank you so much!
I think the key point is, if there are two identical and symmetrical lenses set (or doublet, triboulet) in the system,
when replacing them, make sure that they are also identical and symmetrical lens combinations.
In this condition, you can only replace the left one to stock lens, and just copy and flip for the right one.
Maybe it is not easy to examine the system has identical and symmetrical lenses set.
For example, try to find if there are two surface has the same parameters but only radius has opposite sign, then we can say they are identical and symmetrical.
Yihua Hsiao
  • 66 replies
  • February 16, 2024
Hi all
Starting from 23 R2.01, The Stock Lens Matching tool not only filters out suitable lenses based on the original criteria of EFL and EPD but also introduces support for two new options: Match Shape and Match Orientation.
Please see the KBA for the detail informaion.
https://support.zemax.com/hc/en-us/articles/1500005486781-How-to-use-the-Stock-Lens-Matching-tool
  • 1136 replies
  • February 16, 2024
Great news @Yihua Hsiao
It looks promising. Do we know the shape factor difference range?
a shape factor difference within a certain range
Looking forward to trying this new feature.
Yihua Hsiao
  • 66 replies
  • March 7, 2024
@David.Nguyen  The shape factor difference range is not a open information in the help file.But I think it’s just a range, looks like 10%, 20%.
